Finished layout on C-791 and cut lightening holes with a hole saw on the drill press. Deburred holes. Cut slots in C-791 and deburred. Used the edge of the bench to bend the C-759 and C-660 to match the curve of the square tube on the canopy frame. Took a few tries to get a good curve. Made up a bolt with large washers to go through the canopy latch tube and secure the canopy to the frame. This will ensure things don't slip out of place when marking for the big cut. Put frame in canopy, bolted and clamped into position.
