Brief Description: Fuel Lines and Firewall Doubler
New bender from Ken makes the best bends of all I've tried, but the radius is slightly larger than others. I want to remake the lines connecting fuel filter to pump and fuel valve to filter, however the larger bend radius is causing fit issues with the doghouse. Started new right fuel line but quickly got into fit issues. Decided to change gears and work on the firewall doubler for the fuel line to the engine.
