Received my fairings for the rudder cable exit on the aft fuselage. They are square and cover the mounting screw for the cable clamp inside the fuselage. Decided to round off the leading edge to make the look better and clear the screw. Also had to bend them slightly to conform to side of fuselage. Did layout for mounting holes and drilled the fairings, then match drilled to fuselage.
