Continued with scuffing the doghouse parts then used the squeezer to dimple for rivets. Assembled the doghouse, fuel valve cover, and center cover in the fuselage. Drilled up the mounting screw holes to #30. Marked and drilled the floor stiffeners to #40 for center cover and fuel pump base.
