Stephens Web Site
Date:  11-2-2021
Number of Hours:  3.00
Manual Reference:  Section 8
Brief Description:  Prep for Final Turtledeck Riveting
One of the rivet holes in the 706 bulkhead was elongated when I initially tried to fit the trurtledeck. Instead of drilling it larger I elected to make a small doubler and use a longer rivet. I primed the doubler and used a little glue to hold the tab in place for riveting.
I marked the location for the cutout at the top of the baggage bulkhead for the threaded rod on the track support. I used a pilot drill , then opened hole with a step drill. Used dremel cutoff wheel to connect the hole to the edge. Cleaned up edges with files and scotchbrite.
Experimenting with locating the center rib, I clamped on the roll over bar and the windshield support. This did not provide much useful info, but it did look neat.
Doubler for bad hole
Marking cut out for support rod
Check center rib alignment
