Brief Description: Begin ADAHRS Bracket, Run Conduit
I mounted the flap motor in the F-766A channel as shown in the plans.
Received the ADAHRS bracket kit from Van's and reviewed the installation instructions. Began work by trimming the tab off the side and edge finishing the bracket. Then I put the bracket in the fuselage for a test fit. Dynon instructions say the bracket must be within one degree of level in all directions, so I will need a more accurate way to check that than my bubble levels.
Removed the snap rings from the bulkheads and ran conduit down the center of the fuselage. One conduit streatches all the way back to the tail, the other ends in the bay where the pitch servo and ADAHRS will be.
