Back from Oshkosh. Finished off the flap actuator housing by adding the last nutplates to the brace. Then assembled the housing and marked the left cover to notch it for flap motor bolt clearance. I drilled the center of the notch then used a uni-bit to open the hole as much as I could. Finished off the notch with a dremel sanding drum. Fit check good.
The plans call for putting the wings on next, so I marked the edge distance on the rear spar and the center section attach points for both sides.
