Assembled the F-741 tunnel cover and found I had not prepared for flush rivets. Dimpled the cover and countersunk the side angles. Then used the squeezer to rivet it together.
I back riveted the hinge for the seat support. Planned to use the squeezer for all remaining rivets. I cleco'd the side angles, the bottom hinge and angle, and the top angle to the seat back. Used the squeezer to set the rivets on the side angles. Was also able to squeeze the bottom hinge and angle. Couldn't get the squeezer on the top angle very well. Used the gun and bucking bar. Slipped off on the last rivet and made some dents in the seat back. Flattened with a hammer and dolly and scuffed up for repaint.
