Located all of the parts for the rudder and brake assembly. Edge finished all the F-6117 brake pedals and the F-6117A master cylinder brackets with files and scotchbrite. Cut all the attachment angles from stock as shown on the plans.
Marked and match drilled angles to the pilot's left brake pedal. Match drilled the master cylinder bracket to the angle. Trimmed angle per the plans, deburred all holes, and edge finished the angles. Cleco'd parts together and one pedal is done.
