Brief Description: Begin Installing Crotch Strap Brackets
Began installing the F-7117 crotch strap brackets by locating the kit and instructions for installation. Removed blue plastic and edge finished one set of brackets. Followed instructions to mark the ribs on the left side of center section to locate the bracket. Clamped and drilled the aft bracket to the ribs, clecoing as I went. Made a spacer and clamped the forward bracket to the aft bracket, then match drilled to ribs. Removed all and deburred the holes. Reistalled the brackets and cleco'd on the forward floor. Match drilled the floor to the brackets for the mounting screws.
