Stephens Web Site
Date:  7-5-2019
Number of Hours:  3.00
Manual Reference:  Section 8
Brief Description:  Trim Aft Ends of J-Channels
Began the process to trim the aft end of the J-channels to fit the fuselage. Read several accounts of people coming up short with factory dimensions, so I set up the tail section to measure them in place and make length to fit. Measured and marked the J-channels and cut to fit with the pattern from the plans. Channels ended up a little long and had to be removed and re-cut several times to make them fit correctly. In the end, they came out very close to the dimensions in the plans.
Check length
Check length
Trim per plans
Trim per plans
Adjust to fit
Adjust to fit
