Finished installing the cover support ribs. Lined up the two halves and cleco'd the spacer blocks in place then drilled them for bolts at the top and bottom. Assembled the halves with spacers and bolts. Used hardware store bolts through the wood spacer blocks. Cleco'd on the end plates.
