Set up the stab and clamped the reinforcing plates on to check for location. Measured and marked the vertical stab attach area. Did a final check and marked holes and checked edge distance before drilling. Reclamped all and began drilling the plates to the spar, clecoing as I wnt. Drilled the angle brackets to the plates through the spar.
