Made a template to mark the rivet spacing on the W-716 by drawing a circle the same diameter as the tube, then marking lines 60 degrees apart. I will transfer these lines to the tube to set the spacing for the 6 pulled rivets for the rod end. Thanks to VAF for the idea!
