Brief Description: Drill and Deburr Right Wing Aileron Gap Seal and F
Cleco'd on the flap bracket, gap seal, and the bottom skins to set up for drilling. Drilled all the holes in the parts, skins, and rear spar to final size. Disassembled and deburred all the holes on the parts, spar, and skins. Scuffed the parts with scotchbrite to prep for primer. Dimpled the inboard bottom skin, outboard top skin, and the aileron gap seal with the squeezer. Countersunk the flap brace for the skin to leave a flat surface to mount the flap hinge.
