Brief Description: Continue to Rivet Left Wing Top Skin
Had a few bad rivets from our last session, so I drilled those and removed them. Also used the squeezer to set as many of the trailing edge rivets as I could. The inboard section is blocked by a doubler on the spar and must be done with a gun and bucking bar.
