Stephens Web Site
Date:  6-12-2017
Number of Hours:  1.00
Manual Reference:  Section 7
Brief Description:  Begin Riveting Left Wing Top Inboard Skin
Frances assisted with bucking rivets for the skin. I used the long back rivet set to form the shop heads on the inside of the wing. We started at the center rib and worked up and down every other rivet toward the leading and trailing edge. We went back and filled in the remaining rivets on the rib, again alternating toward the leading and trailing edge. Completed one rib before we moved to another rib, also we alternated inboard then outboard as we did the ribs. Switched rivet lengths and then did a couple of ribs on the inboard section with the wing walk doubler.
Frances bucking rivets
Several ribs finished
Done for today
Done for today
