Brief Description: Rivet Right Wing Top Skin Outboard
I drilled the bad rivets from the inboard skin, then hung the outboard skin, cleco'd it 100% and marked the rivet sizes as with the inboard skin. We continued to back rivet the ribs, starting in the center and setting rivets up and down the rib, then moving over a rib and doing the same. This time we left the spars until the end. Had about 6 bad rivets in this session that will have to be removed and replaced.
