Mounted the fuel tank on the right wing and used half the screws/bolts as called for in the plans. The Z-brackets lined up well, with just some minor josteling with a probe to allow the bolts to be inserted. Screws went into the nutplates on the spar just fine.
Hung the inboard skin and doubler plate and put in about half of the clecos. Went back and filled in the rest of the cleco's and then marked rivet sizes on the blue plastic and some masking tape. Also put tape on cleco's as a reminder for different rivet sizes.
