Brief Description: Edge Finish Right Inboard Bottom Skin
Edge finished the inboard bottom skin on right wing using files, emory paper and scotchbrite. I used small files to work around the corners of the inspection plate cut-outs and followed that with emory paper and scotchbrite. Used the vixen flie, flat file, emory paper and scotchbrite to taper the skin for the scarf joint.
