Mixed 10 grams of sealant and continued to squeeze rivets for tank skin to baffle joint. Set rivets wet, again working from center to outboard ends. Finished all the rivets, finally done with wet riveting!
I also noticed a couple of air bubbles as I put down the bead of sealant for the skin to baffle joint. These had popped leaving a couple of small voids in the surface of the bead. I used some excess sealant inside the tank to fill all of these in.
