Brief Description: Begin Riveting Left Tank Skin to Baffle
Removed all the clecos from the skin to baffle line on the top of the tank, wiped area with MEK and re-inserted every other cleco. Mixed 10 grams of sealant, set up the squeezer for flush rivets, and began setting skin to baffle rivets, working from center outboard. Used wet rivet technique on these rivets.
