Brief Description: Blind Rivet Baffle on Left Tank
Put the tank back in the cradle. Mixed 10 grams of sealant, twirled rivets in sealant and used Stanley rivet puller to install the top and bottom rivet in each rib first, working from center rib out toward each end. Used same technique for rivets on Z-brackets, center first then moving to ends. Used excess sealant to cover the rivet heads. Put the tank back on the bench nose up to help sealant flow back down rivets.
