Brief Description: Prepare Right Tank for Rear Baffle
Cleaned excess sealant from tank skin with dremel scotchbrite and pads. Made sure we had a good path for any water in the tank to drain down to the lowest point. Ran through tank assembly checklist to be sure all steps were completed, and all fittings tight. Rescuffed all mating surfaces on tank, baffle and Z-brackets. Washed all parts in Dawn dish soap and warm water, set out to air dry.
