Brief Description: Rivet Tank Drain Flange and Fuel Cap Flange
I cleaned dimples and rivet holes of excess sealant. Washed appropriate size rivets in MEK and wiped work area with MEK. Used the squeezer to set rivets in the drain flange. Did not get good rivets as the squeezer seemed to shift sideways during the set and cleated 4 of 6 rivets. Used gun and bucking bar to successfully set all rivets for tank cap flange.
Drilled the four bad rivets in the drain flange and removed them. Cleaned up the holes with MEK.
