As on the right wing the leading edge and the top of the wing were a perfect fit right from the start. On the bottom of the wing I had a gap that started about 1/3 back from the leading edge. I removed the tank and removed the end rib. Re-bent the flange and reinstalled all which closed the gap nicely. Match drilled the W-423 through the tank skin, clecoing as I drilled.
