Frances and I turned the left wing around on the stand to allow access to the bottom of the wing. We hung the inboard and outboard skins with a few cleco's along the spar. I proceeded to cleco the skins working down from the spar, and from the center out to each edge. I drilled and deburred all the open holes, then moved the clecos and drilled and deburred the remaining holes. Next step is working the outboard leading edge, so I retrieved the skins, ribs, and the cradle from their storage locations.
