Brief Description: Drill and Deburr Left Wing Skin
I drilled all the holes on the top skins for the left wing. Moved the clecos and drilled the remaining holes. I used a pattern in moving the clecos so I always knew which holes had been drilled. While deburring these holes I realized I made an error in the process. By drilling and moving the clecos I would have to move all the clecos a second time to deburr the original holes. Proper sequence should be drill and deburr all open holes, move clecos, drill and deburr remaining holes. I have started putting notes on the skins as to what I've done as I read ahead in the plans I won't be working with the skins again for a while.
