Brief Description: Continue to rivet skin on Horizontal Stab
Got the "oops" rivets from Avery. I had one bad rivet hole in the leading edge that was easy to get at, and so used that one for practice. Setting the "oops" went OK, so I pulled off the rear spar and set the other "oops" in the center top of left stab. That one worked fine as well. Took one last look around the inside of the stab and cleco'd the rear spar back on and started setting rivets around the edges of the stabs.
