Brief Description: Re-make Front Spar Reinforcing Angles
Match drilled the new angle pieces with the front spar. Marked out the taper and minimum edge distance for the holes. Cut the tapers with the band saw making sure to leave some material for finishing. Used the vixen file to smooth cut marks and finished with a fine file and scotch brite wheel. Then made the bends and did counter sink for flush rivets.
