Carl Bells RV7A N947CB
Date:  5-12-2010
Number of Hours:  7.00
Manual Reference:  Classic Aero
Brief Description:  Re-installation of the interior
This is just the re-installation of the interior to get the plane ready for the inspection and first flight. I needed to make some adjustments from the previous installation because Classic Aero sent the replacement panels for the baggage and they need some fitting. They had to be in before I could mount the front side panels with the Rivnuts. It is all in and done. If I need to remove any thing for maintenance it will take less than an hour to remove it all, it is a great feature.
Today I also noticed a leak in the left brake master cylinder. After a call to Vans, Dale said the “O” ring can have problem if they are in storage too long and they need replacing. They are sending the kit today so I can get the brakes back in working and install the front carpet.
Obligatory 2
Obligatory 2" EXPERIMENTAL
Seat in
Seat in
Side Panel is in
Side Panel is in
