These ramps are standard in all of Vans cowls. The trick is to attach in the right spot, glass them in place and the finish them to a smooth shape for efficient air flow. This doesn't look like much, but there is a lot of work getting them attached, glassed and sanded smooth. I will add one more coat of thinned resin after sanding and then spray filler primer, before more sanding and painting.
