Brief Description: Heat inlet and riveting the front baffles
Today I added the inlet for the heating muff and started riveting the 1# and #2 baffle parts together. The heat inlet has a stainless screen that I sandwiched between the duck flange and the inlet floor, this is per the plans to keep bad stuff out like wasps and other small critters. I also used hi-temp red silicon seal around the joint of the screen, duct and the inlet floor to keep the assembly sealed. t
