Brief Description: Finishing the firewall insulation
I finished the firewall insulation and sound proofing. I continued with the cardboard template but had to use multiple pieces to get around the cables and wires penetrating the firewall. I also made a plug for the relocation of one of the cable to the mixture control; I need to add the picture because the solution was a good one that may help other builders. Basically I used two round plates with platenuts on the inside fire wall plate and used 500 degree silicon to seal the patch. I will add a picture next time.
