This is the start to the taxi, landing, navigation lighting wiring. All these lights reside in the wingtips and require some pretty robust circuits. The landing and taxi lights are 75Watts each, a total of 4 halogen lights. They get wired to the terminal block with 14Ga Tefzel. The navigation lights only require 18Ga since they only draw 2 amps total. I will also run the pitot heat wiring to the terminal block, to allow for and easy disconnect. I addition I wired the emergency bus switch back to the fuse panel and a 20 Amp fuse. This bus will run the radios if I need to shut down the main bus off the master.
