Carl Bells RV7A N947CB
Date:  5-25-2007
Manual Reference:  Dwg 3 & Section 6
Brief Description:  Shaping Hoizontal Front Span Angles HS 714 & HS 71
So, you have to start somewhere and ths is the place. I had to change the bandsaw blade and a sanding belt, but after that all went well. I used a varible speed Sears 59" band saw and a Delta Belt sander. I finished it off with a Microlux hand held belt sander and will give it the once over with a fine Scotch Brite wheel tomorrow, then to Varithane Primer in the back yard paint booth. It's a start and it feels good!
This is how they come out of the box
This is the shape per drg 3
This is the finished part
