Brief Description: Mounting the panel edge padding and lights
Today I started preparing for the canopy construction by cleaning up some lose ends. First, I used the template provided by Classic Aero for the panel brow mounting holes and punched them with a Whitney punch. After mounting the brow I could position the panel LED lighting strip right aft of it, this worked fine. The lighting is good and covers the entire panel as you can see in the pictures.
I also shortened the rudder peddle pull bar, it was longer than needed, why carry the extra weight?
Nice blue glow lighting on a dimmer
Template from Classic Aero for mounting the Skin edge padding
