Carl Bells RV7A N947CB
Date:  6-10-2009
Manual Reference:  None
Brief Description:  Temporary mounting right side switches
I finished drilling the right side of the panel for the last of the switches and the two dimmers pots. Basically the accessory controls such as the panel lights, their dimmers, fans for the defroster and the emergency bus switch are here. I wanted to have these infrequently used switches out of the main switch panel to keep it as simple as possible. I also ordered the switch label plates today from Front Panel Express. They are 1.5mm black anodized aluminum, engraved with the lettering filled in white.
Right side switches
Right side switches
Rear view of the dimmer pots
Aternator field breaker
