Today the GRT AFIS came in and I just had to get it installed. The cutout was a little tight, but I made some adjustments and drilled the 4 mounting holes and did a trial fit. All is good and I think it will look marvelous once I paint the panel. I don't want to do that until I get the Garmin 696 GPS mounted. I also work on the cowl, no pictures required since it was just filling and sanding for 2 hours. More on that later.
