I did the final assembly of the hand brakes, high pressure fuel pump and the seat pans today. Since I went through this when I built the parts, more description is not necessary. I ran out of Torx 6 lobe 8/32 screws and had to order another 100 to finish. I also ran out of LP4-3 pop rivets to finish the fuselage/spar support covers, so until these fasteners come in, these items remain incomplete.
Fuel pump and tank selector valve installed
Hand brakes are installed
Seat pans and the 704 spar support caps are riveted in
