This is the throttle and mixture cable setup, I had to return this cable, it was too short. I used a knock out punch from Harbor Freight for the special fire proof firewall fitting. This mixture cable is also now ready for final installation. I like the flap switch next to the throttle so I can just hit it when I get into the white arc. I still need to take this all apart to paint the panel and fit the canopy, so it will come off in a week or two.
Throttle and flap switch - Mixture will go in the other hole
