Today I decided to get the tie down rings off the bench and build a bracket in the baggage compartment for storage while traveling. I dug up some ΒΌ inch bar, tapped it for the eye bolts and drilled it for the mounting rivet s. I may change it to flush rivet instead of the button heads, depending on the interior from Classic Aero. I also wired the flap system which worked first time. No pictures but you all know what wiring looks like!
