Carl Bells RV7A N947CB
Date:  1-29-2010
Number of Hours:  5.00
Manual Reference:  None
Brief Description:  Mounting the panel edge padding and lights
Today I started preparing for the canopy construction by cleaning up some lose ends. First, I used the template provided by Classic Aero for the panel brow mounting holes and punched them with a Whitney punch. After mounting the brow I could position the panel LED lighting strip right aft of it, this worked fine. The lighting is good and covers the entire panel as you can see in the pictures.
I also shortened the rudder peddle pull bar, it was longer than needed, why carry the extra weight?
Nice blue glow lighting on a dimmer
Template from Classic Aero for mounting the  Skin edge padding
Shortend the rudder push pull bar
