Carl Bells RV7A N947CB
Date:  1-6-2010
Number of Hours:  5.00
Manual Reference:  Classic Aero Inst
Brief Description:  Installing the Classic Aero Interior
While installing the beautiful Classic Aero interior I hit my first problem. The left side fit perfectly and the right side came up ½” short. Surely my plane can’t be ½” shorter on the right side, can it? While after a few measurements, the culprit was the right side baggage panel was ½” too short. I called Classic Aero and they said “although we don’t know how this happened because they are laser cut, they will gladly replace it”. So I will have to wait a few weeks for the new panel, the rest of the panels when it great. I will add more pictures when completed. One word of warning, it would be a lot easier to trim back the upper skin brace on sliders while building, not after the fact if you are using this interior. I also think some more Velcro in a few areas is required and added it as necessary. Last, if you remove a panel for maintenance, reach you hand behind the panel and separate the Velcro, rather than try to yank them off from the front.
Left side is great
Left side is great
Right side Ooops
Right side Ooops
Cut too short at the fatory
