Carl Bells RV7A N947CB
Date:  12-4-2009
Number of Hours:  4.00
Manual Reference:  DWG 4 & 5
Brief Description:  Mounting the elevators and hooking up the trim
I also mounted the left elevator and hooked up the trim tab motor for flying. It will come off again for painting but that should be it. I used small Radio Control connectors for the trim wire and shink tubing them to keep them from separating. When I take the elevators off for painting it is just a matter of cutting off the heat shrink. Next time in the shop I will add the right elevator and the push tube connection to the elevator horn.
Positioned for hook up
Trim moter in place and wired
All mounted
All mounted
