Carl Bells RV7A N947CB
Date:  7-24-2009
Manual Reference:  None
Brief Description:  Wiring is finally done
OK, the wiring is almost done. There is still some hookup to do in the wings when I put them on and I need some more 18Awg wire to hook up the defroster fans, but that needs to be done when I install the front fuselage deck. But, other than that, the wiring is done. I did get everything powered up and tested to a point. The reality is, I cannot check out the GRT EFIS and EM until I program them and that is a big job with considerable planning. I think I will do that after all the construction is done and I can sit in the plane.
GRT and the Garmin 696 fired up, hooray
All the radios are working, I think?
Full panel with everything on
