Carl Bells RV7A N947CB
Date:  6-28-2009
Number of Hours:  3.00
Manual Reference:  None
Brief Description:  Switch Plates and Sheilded Strobe cables
I also mounted the right side switch plate today. The holes on this side of the panel were done by hand not at the panel fabricators, so I was worried the tolerance would be too tight to get the plate on. It was almost “spot on”, I had to slightly enlarge two hole to make everything drop into place.
I also ran the strobe cable through the plane, I had to drill some holes and add some snap grommets, but what’s new. I will add the connectors tomorrow.
Right side switch panel
Panel lights and Dimmers
Strobe cabel ready for the wings
