Brief Description: Installing the Tru Trak Digifight IIVSVG harness
Still more work to do on the auto pilot, but this was good progress. The cable is in place for the pitch servo; I will cut to it to length and add the connector the next time in the shop. I also have to run and connect the power, ground and signal wires. The wing cable won’t get attached to the roll servo until the wings go on for the final time in a few months when the wiring, canopy and fiberglass work is all done. I also ran the coax for the VOR antenna which is in the right side wing tips. This will get pulled through the plastic wire conduit I installed a year ago when I finished the wings. All wires are going through this tube except for the noisy strobe wire which has its own grommets.
