Carl Bells RV7A N947CB
Date:  4-25-2009
Number of Hours:  3.00
Manual Reference:  Various
Brief Description:  Mounting the radio stack
The radio stack mounting required a few phone calls and careful planning. I talked to Paul a Steinair and he recommended supporting the SL 30, because of its length at the sub-panel. I tied the radios together at the rear using the tray holes that are for mounting and then fabricated some attach brackets and a cross angle support under the SL 30 Nav/Comm. This made the assembly very ridged and added the benefit of reducing pressure on the front radio stack mounting angles.
8/32 Screws into the panel angles
Behind the panel view
Rear stack tie and support
