Carl Bells RV7A N947CB
Date:  3-23-2009
Number of Hours:  5.00
Manual Reference:  None
Brief Description:  Fiberglass work
These ramps are standard in all of Vans cowls. The trick is to attach in the right spot, glass them in place and the finish them to a smooth shape for efficient air flow. This doesn't look like much, but there is a lot of work getting them attached, glassed and sanded smooth. I will add one more coat of thinned resin after sanding and then spray filler primer, before more sanding and painting.
Left inlet ramp close up
Upper cowl
Upper cowl
Left ramp from the rear
